Launched in spring of 2014, the OnePlus One packs a 5.5" display and runs the Android-based CyanogenMod 12S operating system. Model "ONE A0001."
110 Questions View all
Installed a replacement screen - Vertical flickering issue
See this video: https://streamable.com/ktkw1
This only happens when the screen is turned on, either when the phone is booted up or awaken from sleep. This issue happens for a few mins then it goes away. The screen looks fine afterwards.
Touchscreen functionality is OK.
I would like to know if this is a defect in the replacement screen or something I messed up during installation i.e. connection etc?
Can someone also explain what is causing this issue? And why does it go away after a few minutes?
Thanks!
Add a comment
1 Answer
It's hard to pinpoint the exact reason for this issue, but the problem may arise because of poor connectivity to the phone's "motherboard" or chip, from pressure on a portion of the LCD that was created during reassembly, or simply environmental factors like heat or cold air. I would recommend reassembling the device. If the condition continues it may be safe to look for a replacement LCD.
Add a comment
Add your answer
Muhammad Sarwar will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 238
