The unit turns off after 5 minutes and coffee gets cold. how to fix?
The unit turns off after 5 minutes and coffee gets cold. how to fix so it stays hot
@jjhiggins3000 use these guides Cuisinart DCC-3200 to work on your coffee maker. It does sound like an issue with either the thermal fuse, thermostat (thermistor), or your timer. you coffee gets cold because the coffee maker turns of and that turns the hot plate off. Make sure that all of your settings are correct for the auto on and off features of your coffee maker. you can download the manual from here https://www.cuisinart.com/share/pdf/manu...
Past 24 Hours: 6
Past 7 Days: 22
Past 30 Days: 91
All Time: 3,760
