Repair and disassembly guides for the Compaq Presario CQ40.
39 Questions View all
Why is my laptop not turning on?
Whenever I switch off my laptop, it doesn't turn off, it just goes to a black lit screen (no I am not joking) and stays like that until the battery runs out. After that, it doesn't even turn on for days. It does switch on after staying Idle for a week or two but the problem always repeats when I turn it iff again.
P.S. It is very old but runs perfectly when it is on, the problem only occurs when I switch it off.
1 Comment:
Hi,
What OS is installed in the laptop?
What happens if you hold the power button to force it to shutdown?
by
Add a comment
1 Answer
Amaan Shikoh this sounds like an issue with your OS as @jayeff is already hinting. You can check if there is a BIOS update for your computer or re-install your OS. In your command line type
shutdown -s -f
and see if that works.
Add a comment
Add your answer
Amaan Shikoh will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 15
All Time: 454
