The B6 and B7 versions of the Volkswagen Passat are front-engine large family cars produced by Volkswagen, a German automaker. The B6 line of the Passat was produced between 2005 and 2010, and the B7 line was produced between 2010 and 2015 as a facelift of the B6 line.
29 Questions View all
Key fob stuck in ignition
Just replaced the battery in my key fob. I got into my car with the normal key, put the fob in the ignition and now it won't come out. Evidently I need to reprogram, but how can I get the key fob out?
Update (10/20/2017)
I realized my car battery was the issue. It was flatlined.
Left headlight was staying on even with key out.
So that seems to be the main issue.
I was able to get the key fob out after jumping the car.
So just trying to find a solution now for the headlight issue.
May disconnect headlight for now so it doesn't continue to drain battery.
Score 3
3 Comments
this worked for me omg thank you so much
by
Glad it worked, pass it along...
by
Add a comment
Most Helpful Answer
Push on brake and hit button forgear shifter a couple of times.
Score 2
3 Comments:
Yes, I had tried this already but it had not worked for me.
I had seen a video showing that.
It would have been great!
Thanks
by
It worked for me. Thank you!!
by
Add a comment
Its answer is pretty simple.
Move your car backward and forward again.
Make sure your handle face front. DO NOT LEAVE YOUR CAR WHEN YOUR WHEEL IS TURNED.
2 Comments:
I was programming my remote key fob now the fob is stuck in the ignition
by
I was programming my key fob and now the fob is stuck in the ignition I can’t get it out
by
Add a comment
Is there a battery in the fob?
If the five won’t come out of the ignition?
Add a comment
Add your answer
Darby Rosello will be eternally grateful.
Past 24 Hours: 4
Past 7 Days: 20
Past 30 Days: 106
All Time: 20,914
