Released in 2012, the Toshiba Satellite C850 is a 15.6-inch notebook with a choice of either AMD or Intel processors. It has USB 3.0 and can be configured with up to a 1TB HDD for storage and discrete graphics.
38 Questions View all
Is it possible to install a SSD (Solid State Drive) into Toshiba C850?
I have a Toshiba Satellite C850 and wondered if it is possible to install an SSD and whether or not it will effectively improve performance speed. Would RAM need to upgraded at the same time?
Add a comment
1 Answer
Chosen Solution
Hi!
You can install a new SSD into your laptop. Use this YouTube video as a guide.
Upgrading your hard drive to an SSD will indeed boost the performance of your laptop, especially when it comes to loading stuff. Like Windows should load up very fast, in a matter of seconds, other programs, like Google Chrome and Office too. It will all feel a lot smoother, as the computer has to spend less time reading data from the drive.
Upgrading to an SSD does not mean that you need to upgrade the RAM too.
Your overall performance however also depends on the other components. Depending on the amount of RAM and on the CPU that you currently have installed, upgrading the RAM would or would not make sense.
If you currently only have 2GB of RAM, sure, go ahead, make the jump to 4, 6 or even 8. 2GB just won't cut it in 2017. If you have 4GB but a weak processor (like a Celeron o Pentium from 2013), adding more just wouldn't make much sense.
Score 1
Add a comment
Add your answer
Lisa will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 17
All Time: 3,471
