Repair guides and support for motorcycles manufactured by Harley-Davidson.
77 Questions View all
rear brake engaging after riding for aprox. 25 minutes
My rear brake get extremely hot and self engages braking the bike after riding aprox. 25 minutes . I have bled the brakes several times with about 2 pints of dot 5 to remove any air and this continues to happen . 1999 softail . Suggestion please !
Score 1
Add a comment
1 Answer
Chosen Solution
@hel69 check your caliper to make sure it is not seized and continues to apply the brakes during normal driving.
Score 2
3 Comments:
Thank you i will continue using the brake I did let some pressure off after riding when it was binding and hot. I think it helped.
by
I have bleed the rear brake many times and still it closes when hot .I'm thinking maybe the rubber hose is collapsing when hot . ill continue to work at it . thanks anyway
by
@hel69 that sounds very reasonable. Let us know what ended up working for you.
by
Add a comment
Add your answer
Harry Helmly will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 15
All Time: 285
