Repair and disassembly guides and support for dish washing appliances.
720 Questions View all
Maytag portable dishwasher starts/stops rinse cycle
I have a Maytag portable dishwasher (model # MDC4809 pab0) that is having a problem with the rinse cycle. It runs through the wash cycle fine, but when it starts the rinse cycle it continues to start and stop over and over again. Also, there is a strange black oily residue all over in the dishwasher.
3 Comments
Thank you, we will look at it!
by
Asked husband, he said that the black residue was sudden and did not come from the door. Whatever occurred that is keeping it from starting the drain process caused the residue.
by
That's why I listed the drain as the first thing to check. Is there a foul smell?
by
Add a comment
1 Answer
Chosen Solution
A restricted drain could also cause this problem. Check your drain hose for a clog or restriction. Make sure that your sink drain and garbage disposal are draining properly. If you have an air gap installed in the drain line, make sure that it is not clogged. If you suspect that the dishwasher is not draining properly but find no drain system restrictions, then you could have problem with the drain check valve.
Your front dishwasher door panel may have a sound absorbing material called black mastic. If this material deteriorates and leaks down into the tub, it can cause spots and deposits on dishes. To check for this problem, you would need to turn off the breaker and pull off the outer door panel of the dishwasher.
Score 1
Add a comment
Add your answer
Angie Wallace will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 614
