Improved second generation Google-branded tablet with a 7" screen.
96 Questions View all
Why doesnt my tablet charge properly with its original charger anymore
I have a Nexus 7 2nd generation tablet and the original charger doesn't seem to be charging my tablet anymore i thought it was the port but, I had it checked out and was told that it seemed a little loose and that's probably why it's not charging is this true?
1 Comment:
Hi,
Can you charge the tablet OK using another charger or when you connect it to a computer?
Can you use a DMM (Digital Muiltimeter -Voltmeter function) to test that the original charger is supplying the correct voltage?
by
Add a comment
1 Answer
I've replaced several of these charging ports due to similar issues. Assuming you've tried other chargers and cables, port replacement sounds like the resolution you'll need. Also be sure to use only quality chargers and cables if you replace the original one. Anker makes great charging products. They're the only brand I use with customer devices. Good luck!
Add a comment
Add your answer
Patricia Ortiz will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 64
