Our group has created a repair guide for the Canon SX40HS digital camera for use by people wanting to dissasemble and or repair their own camera. The guide will contain a troubleshooting page, pictures, and 3 repair guides for common issues with this particular model.
9 Questions View all
Flash tube replacement bulb
I have a trusty sx40 hs but the pop-up flash stopped working (no flash). I think it can be the flash tube but I cannot find a place where I can purchase a new one. If I maybe have the part number it can make it easier to find. Can anyone help me please. Thank you.
Add a comment
1 Answer
Chosen Solution
I'd be inclined to doubt whether it's the flash tube itself unless you can see a visible crack in the glass (most likely around one of the electrodes) - there are probably more ways that the driving electronics could fail.
If you can disassemble the flash head so as to remove the xenon flash tube you can get its precise dimensions and then you may be able to find a replacement on one of the Far Eastern online market places - it's almost certainly a generic part. But probably much easier to replace the complete flash head. There's one on ebay.co.uk currently for £42.50. Or you could put a watch on ebay for a SX40HS for spares or repair with a different fault, which could be cheaper.
But a word of warning - the capacitor (the cylindrical part) may hold a considerable charge for a long time after you switch the camera off, sufficient to give you a nasty shock. Take great care around the flash head until you've had a chance to short out the capacitor terminals with a screwdriver with an insulated handle.
Score 3
1 Comment:
Thank you for the response. I could not see a crack. I cannot find a workshop in South Africa that can test the unit. Maybe I must just buy a flash for the hot shoe. Any suggestions?
by
Add a comment
Add your answer
Herman Malan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 198
