The Sony Xperia M2 is mid-range 4G Android smartphone produced by Sony Mobile. Available - May, 2014.
Not Charging : Dead
Hi Team,
Sony Xperia M2 - Dead Unit.
Device status & measurements :
The fault is Phone is not charging, USB Power ( 5V, 10-20 mA) Battery Charging voltage 1.1 - 4.1V, current fluctuating.
Note : This is liquid damaged device
Observations & tests
  • TH voltage is 1.2V it seems OK
  • There is no BAT EN signal 0.6V
* Phone can be power on when given the BAT+ - to with external power supply
  • When plug the battery connector 0V at battery terminals. that's mean Battery Disable itself
  • When unplug the battery and can be get measurement 3.7V
  • Checked with new battery, same result observed. - Battery is OK
If any idea please comment. Thank you for your time. in simple i need to enable BAT EN signal or need a way to bypass. or Please help to find schematic diagram for D2303
Score 2
1 Comment
Buddhika Mahesh this is going to be tough. There are no more schematics available since Sony does not repair any electrical components anymore.
by
Add a comment
1 Answer
Most Helpful Answer
Buddhika Mahesh the only thing you could try is to hack it together like this
from here
Score 2
2 Comments:
Already checked the path. 2-3 Ohms. 4.9V there. i need to generate anyhow BAT_EN signal. otherwise have to replace PM IC.
oldturkey - As always, Thank you for helping us! :-)
by
Buddika mahesh im from sri lanka is there a way to contact u
by
Add a comment
Add your answer
Buddhika Mahesh will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 2,971
