The first generation Mazda MX-5, or Miata.
Timing belt broke while driving
I have a 1997 Mazda Miata. The timing belt broke and I want to know if there could be any other extensive damage to the engine before I have it repaired. Is there any way of determining other damage?
Thanks;
Pete
Score 2
Add a comment
Chosen Solution
From what I've been able to see on line in miata forums these older miatas are non interference designs that won't eat the valves when the belt turns loose. Removing the valve cover and manually turning the cams can confirm this... If any valves show massive clearances at any point of rotation it is of course indicative of bent valve stems. Naturally if you encounter serious resistance trying to turn a cam you should refrain from forcing it.
Score 4
Add a comment
@fullcircle15 the Miata engines are non-interference engines. You should not have any piston/valve damage.
Score 4
Add a comment
Add your answer
peter shea will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 28
All Time: 3,526
