The MSI GE72 6QF Apache Pro is a Windows 10 , 17.3in, quad-core 2.6GHz Intel Core i7-6700HQ, gaming laptop which was released in 2016.
12 Questions View all
Headphone Jack Weird After Physical Damage
I recently tripped over my earbuds when walking away from my computer and ripped them out of the headphone jack. This caused the metal piece at the front to break off and fly across the room. I found it and it seems like it wasn't attached to any wires or connections. Now when I plug in my earbuds it doesn't detect them normally. It plays audio through both my earbuds and my computer unless I mute my audio. When I mute my audio it plays only through my earbuds. I guess I can deal with this, but I'm wondering if there's a quick fix, and if not if there is a way I can make sure it doesn't get damaged further.
1 Comment:
I had the same problem. I soldered it again. But the sound comes from the headphone, not the speaker. What can I do, can you help me? My e-mail is y.akifender@gmail.com. You can send an e-mail to this e-mail. Thank you very much in advance for your help.
by
Add a comment
1 Answer
The audio jack has 3 rounded pins inside the female connector. 3 also lead in from the rear of the input.
This lets the chip turns the audio build in speakers or jack on and off.
Like myself. You are going to have to open it up. Inspect the audio jack. Come the the conclusion the jack
numeric value is near impossible to read and hunt for a replacement. This is going to require a complete
disassembly of the laptop and motherboard/pcb components from the case, and if your not confidant
you can restore it… Take it to a shop that deals with electronics. New jack. Solder, Wick, Solder iron is
required. + a precision screwdriver of the + variant.
Add a comment
Add your answer
Ethan Wilson will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 10
All Time: 250
