The HP Officejet 6600 Inkjet Multifunction Printer is a 4-in-1 device that can print, scan, copy and fax.
62 Questions View all
Ink system failure message
The message says the printhead appears to be missing, not detected, or incorrectly installed.
I uave done everything HP told me to do and I still have this error. It looks like the black ink spilled inside the printer. Xan I have this repaired or should I just get a new printer. I have already tried to clean all of the ink out but I can't reach inside to get it all out.
Score 1
2 Comments
I tried one thing once. And it worked then it messed up again. Now it says print head appears to be missing,not detected, or incorrect.y in
Stalled
by
It worked for me on the, ow it doesn’t work
by
Add a comment
1 Answer
Most Helpful Answer
Printhead issues are very common in this line of printer. I believe you can replace this yourself. You can simply use a cheap refurbished from Ebay. ($29 ish)
Here is a printhead replacement video for a 6700
https://www.youtube.com/watch?v=jSPXV3an...
Score 2
Add a comment
Add your answer
Sam Bird will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 15
All Time: 2,397
