Released around 2010, the Dell Inspiron 15R N5010 is a 15-inch laptop with an Intel processor and dedicated ATI Radeon graphics card.
50 Questions View all
Problem with 8 beeps of Dell Inspiron N5010?
I have Dell Inspiron N5010 and when I turn on power, I get 8 beeps and the screen is black (nothing comes on the screen)
I used external monitor to connect it with my Laptop and then the windows tries to start but every time back to the menu of selection normal mode or safe mode. When, I choose normal mode, it doesn't work and back to the same menu. But, it works if I select safe mode, also, beeps continue while it works on safe mode.
I changed LCD but the problem is same
Any suggestion
Add a comment
1 Answer
Most Helpful Answer
@ka123 8 Beeps is usually a LCD or cable failure. Try this first :
"If the LCD on the system does not show any display, here are some basic steps that you can perform:
Remove the battery and AC Adapter from the laptop and press the power button down for about 10-15 seconds to release flea power.
Power up the system and then press the F12 key during the boot process to get to the Boot Menu, if you are able to see the display.
It may be necessary to repeatedly press the key during the start-up process.
Use the up and down arrow keys to select <Diagnostics> on the menu and press the Enter key.
Or
Hold down the Fn (function) key
Power on the notebook
You should then see the Dell logo screen with the message 'Diagnostic boot selected' in the top corner.
You can then release the keys
While the LCD BIST test runs, the LCD is operating on its own, free of the video controller, which may be discrete (a video card) or on board (on the system board). The test allows you to distinguish an LCD panel problem from a problem with the controller. If the colors are displayed across the screen without a problem, then the issue is not with the LCD." from here. If the test shows that you have a broken LCD, download the service manual from here to see how to change the LCD.
Score 2
Add a comment
Add your answer
kasem will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 14
All Time: 4,942
