Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
White lines on screen
Hi all,
A friend showed my their iPhone recently, and it has white lines up and down the screen. The lines are moderately wide and fairly equadistand from each other. He has had the phone for two years, and the lines showed up just a few days ago. What is causing this problem, and how can we fix it?
Thanks in advance!
Score 2
Add a comment
Most Helpful Answer
Jack,
This could have happened due to the phone being dropped as well. If no repairs were performed a drop could cause the flex cables to lose contact with the LCD contact glass causing the glitch you describe. You have to replace the screen in this case for a successful repair!
Score 1
Add a comment
You can get this after changing the screen , it normally occurs by accidentally damaging the flex cables or the LCD. So if screen has not been changed recently I'd say the LCD is going faulty.
2 Comments:
I don't believe any repairs pere performed. I can check, but is there any other possible cause?
by
If repairs have been done then it's either - damaged flex cables, or damaged LCD. If repairs have been done in the past then they might not have put the metal plate back on that holds the flex cables in place and one of them has become lose. Other than that try a new screen as the LCD maybe going faulty.
by
Add a comment
Hi Jack,
Danny is right, the only way to get these lines is either someone damaging the flex cables or the LCD has had a knock or water damage and is going faulty.
Add a comment
That also happened with my iPhone 4s it could be damaged LCD or flex cables. Take it to the apple store or ifixit to repair your iPhone i hope it helped you
Add a comment
Add your answer
Jack will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 30
All Time: 16,909
