LG's flagship smartphone, with a unique slide-out battery and detachable I/O module supporting multiple hardware expansion options. Released in April 2016.
146 Questions View all
Replacement 16mp rear camera is unfocused and "nodding"
The replacement camera focus is stuck and blurry, the quality looks arguably worse, and it "nods".
When I hold the camera still, the camera shifts downwards then back to the centre (when holding portrait-view-- left/right in landscape). You can see the camera lens move if you look directly at it.
I'm not sure what to do to fix this, or did I get a faulty one? When I opened the package, the camera was at the bottom of the box and not cushioned in-between the packing material so could it have been damaged during shipping.
Score 1
Add a comment
Most Helpful Answer
Hi Kimberly,
That camera sounds like it's damaged, so you should consider returning that one and getting a new one.
- Jasen
Score 2
Add a comment
Hi Kimberly, I had the same problem until I reboot the cellphone with factory settings a few minutes ago. It now works perfectly fine.
Add a comment
Add your answer
Kimberly Fong will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 636
