Released April 2014, the Canon PowerShot G1 X Mark II is a point and shoot camera that offers professional level controls.
6 Questions View all
LCD display goes blank when I move it out to use it at an angle
With the display in the normal position it works. As soon as the display is pulled out to angle it the lower edge drops down on the hinged mechanism as designed, but when this happens the screen goes blank. If I use my hand to hold the screen up as I pull it out the display works as normal. I think there is a connection under the LCD which is causing the problem when the screen slides down. I am worried I may break the camera if I take the display apart as I have no manual. Has anyone come across this problem and is there a fix for it?
Thanks
Score 3
Add a comment
Chosen Solution
There's a very good disassembly guide for this camera: Disassembly Guide
Removing the back including the hinged screen should be pretty easy. Reinserting the ribbons in Step 10 may be a bit fiddly and may require tweezers, but you will succeed with a bit of patience.
It doesn't describe how to disassemble the rear panel but it shouldn't be too hard. Take great care of any springs so you know how to refit them, make lots of notes about where screws come from, and keep them separate as there may be several sizes. You may find a loose connector, or maybe a ribbon bonded directly to the LCD, in which case a little bit of packing inserted behind it to increase the pressure may be sufficient to fix it.
But if the worst comes to the worst, put a watch on eBay for one advertised as "spares or repair" but with a good screen. Lens errors may well be much commoner. A swap-out should then be pretty straightforward.
Score 4
Add a comment
I’ve disassembled the screen (2 screws top edge and 3 screws visible when screen is at right angle to the camera and you push screen towards camera (spring loaded). There is a flexi cable that is bent 180 degrees when screen is reassembled.. On my camera one of the wires in the flexi cable is broken. It makes a connection when screen is not tilted. I need a new cable and I don’t have the tools to replace it. Shocking design in my opinion. Every time the screen is tilted the cable is stressed mechanically . On might argue it’s a systemic fault and not fit for purpose but doubt if Canon would accept this argument.
Score 1
2 Comments:
I got the same problem (Screen shuts off when I swivel up the screen - selfie mode, but works fine when I swivel down - periscope mode) I bet the flexi-cable has a broken thread. Can one buy just that piece and self replace it? Where to buy the cable?
by
I have the same problem, but I don't know if the problem is the black flex cable.
I checked it to visualize any problem but apparently I can't see any problem.
by
Add a comment
Have same problem
Seem to be the little magnet under the upper screen case
Very difficult to maintain in place and in the right orientation
1 Comment:
I have the same problem too, but I do not understand your solution.
Did you exchange the complete display or did you fix those magnets somehow?
What did you have to disassemble?
Thanks
by
Add a comment
I have the same problem, but I do not understand the solution above.
Did you fix it in the meantime? How?
Add a comment
Any Infos about it? I have the same problem
Add a comment
Add your answer
Alan Cattalon will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 29
All Time: 2,796
