This Power Mac G4 has Mirrored Drive Doors.
CD boot
Will not boot from Apple Install CD or Diskwarrior CD. Optical drive kick CD out when pressing "C" key. Any suggestions?
Score 1
1 Comment
Check your drive works, can you boot from hard drive?
by
Add a comment
Most Helpful Answer
What install CDs have you been using? The mirror door G4s are a fussy set, will only boot from OSX 10.2.2(approx and above) CDs, not OS9 CDs (even the dual boot models).
If the machine is booting, check the machine can see the CD or DVDs ordinarily, if it isn't the optical drive has probably failed. The last few of those I've looked at I've had to put a new DVD drive in them as the laser had failed.
Score 1
Add a comment
Try holding option down instead, if you manage to boot to the selection, then select the DVD.
What exactly is wrong with your computer that you need to boot from your install disk?
Score 1
Add a comment
Add your answer
pete surckla will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 10
All Time: 4,520
