The second generation model's body has a wider track and longer wheelbase than the previous MDX. The engine was upgraded to a 3.7 liter V6 tuned for 300 hp. It accelerates from 0-60 mph in 6.5 seconds, one of the most powerful engines Honda has produced to date.
12 Questions View all
Why is my idiot light on a 2007 Acura DMC saying "Battery not charging
I have a 2007 Acura DMX. Today (11/21/2017) I took the car out in a heavy rain. Eventually, I lost power. Pulled over side of the road, waited awhile and started car up again. Idiot light came on to say "Battery not charging" but I could run the car. However, power steering was totally gone and had great difficulty in turning the wheel in either direction. I thought everything had gotten soaked from the heavy rain. It is now 8 hours later. Car is parked in a warm garage in my house. Turned up car again. Again, idiot light came on, "Battery not charging". What should I do in this situation. Thank you.
Add a comment
1 Answer
Most Helpful Answer
@expofrosty double check your belts. Since you have no power steering and your "Battery not charging" could be a sign of a broken alternator belt. If the belt is okay you will have to consider to get your alternator checked (try places like Autozone or your dealer) with a worst case scenario of replacing your alternator. Check on here for that.
Score 2
Add a comment
Add your answer
Bob FitzPatrick will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 20
All Time: 196
