Shark Ultimate Professional 1800-watt clothes iron, identified by model number GI505.
9 Questions View all
Iron not powering on
My Iron is plugged in and is still not powering on or heating up, could the cord be broken?
Score 2
Add a comment
Most Helpful Answer
Have you tried a different plug? Or maybe the iron needs more water.
Score 3
Add a comment
Open it up using this guide and then use a multimeter to test it:
Shark Ultimate Professional Circuit Board Replacement
Score 3
1 Comment:
Would you be willing to work on an iron?
by
Add a comment
This Happens sometime, If you forgot to switch off your iron it get over heated and may melt the wire of circuits of the iron.  I have gone through it, Do check your Wires properly. Also check the power wire fwether it get burned out or not.  You may need to replace whole wire.
In case you are planning to buy Get it here: - Best Steam Irons in market
Score 2
1 Comment:
If you know someone who would be willing to work on an iron, I would like to mail it to them and pay for the service. Thank you, Stephanie
by
Add a comment
Add your answer
Matt Brunswick will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 69
All Time: 6,063
