How much would it cost to repair my charging port that doesnt charge all
It doesnt charge and when i put the Charger in a small piece fell out of the charging port
well you can take it to a local repair shop. Most shops will charge between 70-100$ CAD to replace a charge port on that model.
what if you have rice stuck all the way in the back of the charging port how much to get that fixed for a 6s or is there a way to get that out
O.k, you have a grain of rice stuck in your tablet's or phone's charge port. Here's what you need to do!
Get a flashlight, a stick pin, and glasses if you wear them, you don't want to touch or ruin a delicate part inside of that tiny hole. Shine the flashlight straight into the port, take the pin, "preferably a long stick pin" then go ahead and try to poke the grain, and bring it out, that simple. Or use a suction method.
GOOD LUCK!
S B
It varies, if the cost to repair the charging port is higher than the original cost of your tablet, I suggest purchasing a new one. The costs of tablets are not expensive as they used to be. Now days you can get a decent tablet for $99-$200, but that depends on the brand, style, and gigabyts, 4,8,16,32,64, and up. And always get a second, maybe even a third opinion, when it comes to getting something repaired, there are scammers out to RIP you off!
GOOD LUCK!
S B
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 69
All Time: 17,755
how can I fix mine bc its not working
by lisacoleharris
I cant get mine to do anything it just wont charge , it use to go on and off
by clementsmary57
When i plug into the port the bell sounds. But as soon as I let go; the charging signal disappears. I cant get the plug to hold onto the inside of the phone i guess?
by peterjmic
Hi, wanted to ask how much would it cost to fix a charging port on a Samsung device please
by adrian ashworth
Hi @ adrian ashworth
What is the model number of the device?
by jayeff
