A1706 / EMC 3071—Released in November 2016, this 13" Macbook Pro introduces the OLED Touch Bar. Features a dual-core "Skylake" Intel Core i5 CPU and four Thunderbolt 3 ports.
241 Questions View all
Display flex Cable is corroded in search of replacement
I have taken apart my MBpro TB and found that 2 or 3 gold connectors have corroded on the flex cable connecting the display to the motherboard.
Not the separate display mobo but the cable coming from the motherboard. That is connected to underside and display assembly.
After cleaning MacBook out i tried reversing the connection to rule out screen being faulty. Nothing. Anyone have a spare flex cable? Willing to pay all shipping for it.
Or anyone know a trustworthy medium that would sell just the cable?
update: added pictures
Where
bottom MB
LCD Ribbon
LCD port
Score 2
1 Comment
What is the effect of a bad display flex cable?
by
Add a comment
Chosen Solution
Sounds like you need to replace the flex cable, no? https://www.ebay.com/i/132408057873?chn=...
Score 2
6 Comments:
Thank you for your answer AllenWilson33!
But wouldnt this ( https://www.ebay.com/itm/New-LCD-Display... ) be the better alternative just because it actually looks like the ribbon? Thanks for the heads up though I had searched eBay but with the wrong search terms it seems.
by
You know your cable best. I work in SEO so I'm glad my brainstorming helped get you closer to the right query. I was going to note that the rubbing alcohol should be 90% but you are using 99% haha!
You are also correct about q-tips being no bueno.
Hair driers are also verboten in my book because of the possibility that you might heat up soldered components (or melt plastic in this case.)
I'm not a purist or even a very careful repairman with cars or computers, and i don't always take these precautions for the sake of convenience, but if you take these type of shortcuts on say, 1,000 repairs, you are bound to experience catastrophic loss of the device at least a few times, if that makes sense.
by
Replaced the cable yet the display won't turn on again. Already ordered another cable in fear of having fried this one too. That or maybe the (display-)motherboard has giving up on the connection?
by
Sounds like the graphics card might be shot out, in effect rendering the logic board dead until the GPU is replaced (by a shop that has the automated computer /laser/whatever-they-use machine for such work. )
If I'm not mistaken, the litmus test for that is whether you can power external display or not.
Have you tried booting to external?
by
I am now typing on the MacBook Pro whilst being connected to my living room TV. Did a cmd-D boot and it responded with there might be a display problem DV001. So the display is lost I assume. Nothing else out of the ordinary.
by
Show 1 more comment
Add a comment
Before replacing try cleaning with rubbing Alcohol and then dry really well and try again.
If you have any questions or concerns please comment below! Thank you
Score 1
9 Comments:
I have had removed the flex cable and put in 99% alcohol to remove any corrosion. After letting it soak for two hours I put it out to dry for a day. Just now before posting the q reassembled my MacBook to no avail. I fear the connections are fried on the flex ribbon. If needed I can post pictures of the cable.
by
Can you please Post pics I might have an idea depending on how bad it is
by
Have you tried q-tips and rubbing alcohol or try to pick out with so tweezers that might help
by
Would you mind checking this thread tomorrow? I know for sure I’m able to tear down my laptop tomorrow morning. Thanks for your help Walker Young
by
Yeah that’s fine I get notafactions if someone post on here so yeah that’s fine
by
Show 4 more comments
Add a comment
Nice, i washed this little flex cable and the connector on the mobo, and everything just worked. did not expect that
Add a comment
Could anyone say to me, if this could be my issue ( I do not habe Idea what it is) and cannot clean?
Add a comment
Add your answer
Umar will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 11
All Time: 8,563
