Released by Samsung in March 2016. Model SM-G930, Versions: G930F (Global); G930FD (Global; Southeast Asia); G930W8 (Canada).
Finding IMEI with FRP lock
hey guys.
Im looking to get the IMEI off of a board i got delivered. but its FRP locked. there are no identifiers on the board itself, and the dial code *#06# doesnt work because emergency caller wont allow it.
Am i missing something as to where that should be recorded? i know iphones have the "i" at the bottom corner, but samsung doesnt appear to have it.
Score 7
Add a comment
Most Helpful Answer
Does Download mode or Recovery mode show the IMEI?
Download Mode may show through adb?
Score 3
7 Comments:
neither of them show the imei. Im currently installing ADB to run through the last suggestion. while im doing that, do you have the command i would use to pull the IMEI through adb?
by
adb shell dumpsys iphonesubinfo
by
i get No device/Emulator found When i try to connect. i Have Google USB drivers installed in my SDK manager.
by
Removed comment.
by
Show 2 more comments
Add a comment
press volume up, power and home buttons all at same time. While holding down all 3 buttons the screen will start to flash and immediately let up on buttons and hit volume down and the IMEI, SKU and SN will appear on the screen.
Score 1
1 Comment:
Should the phone be off or on ?
by
Add a comment
if the battery cover is original it will have the imei at the bottom, hard to see i suggest some kind of led light to shine against it
Add a comment
Add your answer
Scott will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 39
All Time: 12,383
