Released in 2014, this pay-as-you-go Android Smartphone provides convenience with an affordable price.
13 Questions View all
Why LG Optimus cant fully boot? It keeps shutting down and restarting.
I have an older model LG Optimus Fuel, and it has been fine except for running out of memory, so I kept having to delete apps to free up memory. Now When I turn it on, it can't seem to finish a complete boot cycle--it just gives up after a bit and restarts itself. This will continue indefinitely unless I take out the battery. No combination of holding down any buttons seems to bring it to a new, safe mode or memory. There doesn't seem to be anything i can do except hit the factory reset button. Is there anything else I can do?
1 Comment:
This is not the case, as my battery usually lasts more than a day at a time. Thanks, though
by
Add a comment
Jc H the very first thing you want to do is to replace the battery. A failed battery (no longer holding a full charge and/or supplying full amperage) could cause symptoms like you describe.
Update (12/26/2017)
Jc H if this is still the original battery, it is absolutely possible that it is failing. This does happen from one day to the next. If nothing else, a new battery will give you a known-well starting point.
1 Comment:
Thanks, I will try that. It seems dubious to me, because it still happens when it is plugged in, or when the battery is at 100%. But I have been using a different charger cord lately, and that could account for it.
by
Add a comment
I have this too, I replaced the battery a month before it began so I know it s NOT battery related.
Add a comment
Add your answer
Jc H will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 18
All Time: 406
