The Nintendo Switch is a handheld game console that can be played on the TV via a docking station, or on the go. Released March 3rd, 2017.
694 Questions View all
Replacing the Digitizer - What adhesive to use?
Long story short, I have scratched the plastic screen on my Nintendo Switch.
I discovered that there are replacement digitizers on eBay and Aliexpress available already. However, it seems that all of them do not come with adhesive preapplied.
Does anyone know what type of adhesive is used inside the Nintendo Switch that is glueing the digitizer onto the housing?
Thank you very much in advance!
Score 5
Add a comment
Most Helpful Answer
I purchased a set off of Amazon that came with "tools" and a roll of 1mm double sided adhesive tape. You would just lay a strip down and then pull of the non stick side. Pretty easy to use. The tools is comes with are pretty useless though (bad screwdriver, and doesn't have tri-wing screwdriver).
https://www.amazon.com/KR-NET-Screen-Dig...
Score 1
Add a comment
Only 1 mm, isn't it too little ? Some recommend 3M but never precise the width.
Add a comment
Yes It Is Too Little, Had To Order New Strips, Don’t Know What Size yet.
Add a comment
Add your answer
[deleted] will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 41
All Time: 8,107
