Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
Screw identification help iPhone 4
Does anybody have a layout of what screws go into which hole?
There are several obvious locations for the washers and broad head screws but a majority of them are a mystery if you don't keep track of them.
I had an orderly system set up but I tipped my tray and it's all jumbled. On top of that I lost a handful of tiny screws so I ordered a replacement kit.
I want to make sure i'm doing it right this time and based on just numeric descriptions "2.5mm" i'm unable to determine which screw is what.
Score 1
Add a comment
Chosen Solution
Here is a chart I created for Verizon iPhone 4S.. Does not include the 6 screws and washers holding the LCD to the mid frame, since you do not need to remove them ..
Size Type Location
3.6 mm - Pentalobe - Dock Connector
1.5 mm - Phillips - Battery Connector
1.8 mm - Phillips - Dock Connector - Logic Board
1.6 mm - Phillips - Logic Board near vibrator
1.3 mm - Phillips - Rear Camera - Red
1.5 mm - Phillips - Rear Camera - Orange
2.4 mm - Phillips - Rear Camera - Yellow
4.8 mm - Flat - Top near headphone jack
2.5 mm - Phillips - Top near power button
3.4 mm - Phillips - Near vibrator motor - Red
3.6 mm - Flat - Near battery - Orange
2.4 mm - Phillips - Speaker enclosure
1.6 mm - Phillips - 1 of 4 corner
1.6 mm - Phillips - 2 of 4 corner
1.6 mm - Phillips - 3 of 4 corner
1.6 mm - Phillips - 4 of 4 corner
Details:
Size Amounts Type
1.3 mm - 3 - Phillips
1.5 mm - 2 - Phillips
1.6 mm - 5 - Phillips
1.8 mm - 2 - Phillips
2.4 mm - 3 - Phillips
2.5 mm - 1 - Phillips
3.4 mm - 1 - Phillips
3.6 mm - 2 - Pentalobe
3.6 mm - 1 - Flat
4.8 mm - 1 - Flat
Total 21
17 Phillips
2 Pentalobe
2 flat
Score 2
1 Comment:
Where do I find IFIX shop around Johannesburg in South Africa to purchase this screw drivers?
by
Add a comment
This is also helpful http://www.powerbookmedic.com/wordpress/...
Score 1
Add a comment
The title of this is "iPhone 4" but the list of screws is for "Verizon 4S" and some screw sizes will differ. The screws in the iPhone 4 can be the same length but some differ in diameter. A calliper is instrumental in defining the sizes.
Also, I'd like to suggest using rubbing alcohol and a screen cleaning cloth for cleaning connections. It doesn't leave a film and evaporates quickly, so no need to "dry" after use. Just don't use excessive amounts.
Cheers and good luck!!!
Score 1
Add a comment
All I can say is to maybe look back at the teardown and compare size & shape.
I recommend using this next time:
http://unitediphonerepair.com/?option=co...
Add a comment
Add your answer
charles will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 33
All Time: 32,604
