Premium 11-inch laptop with a 4k touchscreen and movable screen. (Model: L15W-B1208X)
3 Questions View all
I get a message that says to reboot when I turn on my laptop.
When I turn on my laptop the Toshiba logo comes out as normal but then it turns all black and a message comes out that says “reboot and select proper boot device or insert boot media in selected boot device and press a key”. I have tried several things. There was one method that worked for many people and it was to go to the bios menu, disable the secure boot then go to system configuration and change the boot mode from Uefi to csm. I went to the bios menu and disabled the secure boot but when I go system configuration the boot mode tab does not even show up. I have no idea how to fix my laptop please help.
Add a comment
1 Answer
Most Helpful Answer
Your Harddisk is probably dead, how long do you have it? You can try getting the hard drive out and plugging it in a pc and see if it gets connected. If not: its probably dead. If that is the case, just replace the harddrive and install Windows
Score 2
Add a comment
Add your answer
Monica hernandez will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 214
