The Acer Aspire Switch 10 SW5-011-18R3 is a 2-in-1 Tablet with docking keyboard running Windows OS. It was originally released May 2014.
13 Questions View all
Recovering data with broken system
Windows 8.1 won't boot on this device. I have some important files to recover from it. Bootable usb with linux doesn't help. Is there a way to get them back?
6 Comments
Do you have a working desktop PC? So you could test the disk.
by
i have but im not sure if it has internal hdd
by
How did it break? did you drop it? spill something on it?
by
i installed updates and the system crashed
by
Problem fixed: i booted the windows 8.1 usb drive, then launched cmd. Using it I managed to move all the files to the usb. However switching between the drives doesn't work without "cd /d c:\".
by
Show 1 more comment
Add a comment
1 Answer
Most Helpful Answer
You can try using an external USB adapter for the drive and then connect it to a working computer to try to copy your data.
Score 1
2 Comments:
does it have hdd though?
by
HDD or SSD? both should work fine with a hard drive docking station. You can find them on amazon I'm sure, or just open up your desktop and connect with sata.
by
Add a comment
Add your answer
Tomasz Kowalski will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 12
All Time: 429
