The March 2015 update of Apple's 13" MacBook Pro Retina Display, model A1502, features fifth-generation Intel Core i5 and i7 processors and introduces the Force Touch trackpad.
Upgrading my Mac system's SSD
I have A1502 MacBook Pro (mid 2015) this is the last 4 letters of the serial number : FVH3
I wanted to ask which ssd can I use to upgrade to 512GB ?
Can I use this one? Samsung 960 pro M2 512GB
or this one: Samsung 960 EVO
thank you all
Add a comment
1 Answer
Chosen Solution
Your system uses a custom blade SSD which happen to be made by Samsung for Apple, while similar to a M.2 SSD it is not pin compatible. Your system has a AHCI/PCIe x4 (4 lane) interface.
I would recommend you stick with the correct drive made by either OWC or Transcend. Both make replacement SSD's designed to work in your system.
Here's the IFIXIT guide to replace the SSD: MacBook Pro 13" Retina Display Early 2015 SSD Replacement
Score 1
4 Comments:
I saw that in 10.3 ( high siera) apple support custom ssd
Or that isnt true?
by
I'm not sure I understand what you're saying here. There are mechanical & physical limits within your system. The issue is not software you can only use a AHCI/PCIe SSD not a NVMe/PCIe SSD.
Think of it like gasoline and diesel fuel they both run cars & trucks but you can't use one fuel for the other.
by
https://eshop.macsales.com/item/Other%20...
I guess I will stick with this one then :)
I saw not much AHCI ssd out there and most are disconnected...
sad to see apple only used this type as her MacBooks ssd
ty sir anyway :)
by
@fooad444 - Apple was ahead of the curve with blade SSD's.
The issue you're facing is just the speed of change! AHCI based systems are still being sold from Dell and Lenovo. But, the move is on to NVMe/PCI for the upper end systems!
All of the 2016 and newer Mac's use NVMe drives. In fact Apple's new iMac Pro is using interleaved raw flash which is even faster than NVMe based SSD's!
by
Add a comment
Add your answer
fouad taha will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 11
All Time: 6,508
