A gaming laptop released in the Asus G74 Republic of Gamers series in late 2011.
7 Questions View all
Where can I find the ribbon cable to the Power Button?
A client has brought me his Asus ROG G74SX laptop and the power only comes up for a couple of seconds when pressed. ALL the LEDs light up briefly, nothing happens on the monitor, no POST, etc.
As I was inspecting the interior, I noticed the "Sumitomo-g AWM 2896 80C VW-1 -F-" (this is printed on the cable) 10 pin ribbon cable (I count ten contacts on the clips, so I assume its a 10 pin cable) is horribly crimped and might be suspect in the issue. I cannot find a replacement anywhere nor can I find a parts list or a Service manual to the laptop, just the user manual which you already have a link to from here. Its the cable that runs from the powerbutton finger board to J5601 on the motherboard.
I keep getting stonewalled from ASUS and various suppliers because they want the Serial Number (S/N) and the sticker has worn off the laptop and the client has none of the packaging, manuals, etc.
Can anyone assist? Thank you.
Sean M.
Add a comment
Chosen Solution
Hi,
How long does the cable have to be?
Here is a link to various pin numbers, same spec'd cables.
For example if you got the 12 pin cable as long as it was the correct length (or just a bit longer) you could peel 2 wires from it to make a 10 wire cable.
Just a thought
Update (02/06/2018)
Hi ,
Here is one supplier
Score 2
1 Comment:
I did not know you can do that! I will consider that as a last resort but I was hoping for an exact replacement because I would like the tabs at either end that helps with getting them into place and securing them snugly. I measured the original cable at about 6 inches.
Thanks again for the response.
I also finally found the part number thanks to a business in the UK, unfortunately they are out of them. The part number is:
"14G124150103"
Thanks again for the insight!
by
Add a comment
You know where a left shoulder button is on a Nintendo DS? Well, on a DS, the ribbon cables are under the left shoulder button....
So you should check the top left corner of the computer.
Add a comment
Add your answer
Sean Mohrhoff will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 18
All Time: 1,728
