Known as the Canon EOS Rebel XTi in North America, the XTi is a budget Canon DSLR released in 2006 with a 10.1 MP sensor. Also known as the EOS 400D and the EOS Kiss Digital X.
13 Questions View all
NEED HELP! Camera will not turn on!
My battery is fully charged, but it will not turn on. Please help me figure out how to solve this issue!
Add a comment
1 Answer
Chosen Solution
First check the battery compartment door. There is a micro switch that turns the camera off when you open it. If the battery cover does not press down on the switch, the camera won't go on. Make sure that the battery compartment door covers the batteries so that the micro switch senses that the cover is closed.
Score 1
5 Comments:
I have tried that and it did not work
by
having the same problem with my canon rebel, did you ever find a solution
by
I have the same problem. Is there a solution?
by
I found that this switch is broken on my camera, so is it possible to disable the battery door switch?
by
@zea213 Take the camera apart, remove the main board, and put a jumper wire on the board. Seal it with UV-curing resin.
by
Add a comment
Add your answer
Joselyn Vele will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 2,255
