What I need to do to reset my laptop from black screen status?
Reboot problem and always says that Your pc ran to a problem and need to restart" i guess i can restore in factory settings my laptop but my problem is I can't go through the process after turning it off'on again and pressing the f8 anyone have the same problem before? Please help me and guide..thnx
2 Comments
Hi @kerab0416 ,
What OS is installed in the laptop?
by
Windows 10 sir...
by
Add a comment
1 Answer
Chosen Solution
Hi @kerab0416
Do you get the Dell splash screen OK on startup?
If you do try getting into the Windows Recovery Environment to see if you can repair the startup.
To get into WRE start the laptop and when it starts to boot into Windows, force stop the laptop by holding the Power button until it shuts down.
Do this 3 times i.e. start > boot > force shutdown > start > boot > force shutdown etc.
On the 3rd attempt it should boot into the WRE.
Select Troubleshooting > Advanced > Startup Repair and follow the prompts.
>>>>>>DO NOT select Reset this PC as this will re install Windows and erase all your data.<<<<<<
If you cannot get into WRE for whatever reason, have you got a Windows Recovery USB?
If not you can create one from any known working Win 10 computer. All you need is an 8GB USB flashdrive and 40-60 minutes of time. In the "host" computer go to Control Panel > Recovery and find the link "create a USB recovery drive"
When you have the USB recovery drive insert it into the laptop and then select F12 (I think- not sure for your laptop, check your User guide) on startup to alter the boot options to boot from the USB drive first. Then restart the laptop. If it doesn't boot you may have to go into BIOS (F2 or Del - not sure) and enable USB legacy support or CSM.
Hopefully this is of some help.
Score 1
1 Comment:
I will try to do this sir and give you feedback. Thank You!
by
Add a comment
Add your answer
Ivann will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 4
All Time: 1,486
