Model A1419 / EMC 2806 / Late 2014 or Mid 2015. 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (iMac17,1) All with Retina 5K displays
576 Questions View all
Replacing HDD of 5K iMac Fusion Drive
Hi,
I plan to replace a few parts of my 27” iMac as soon as the 1-year warranty is over. I‘ve seen the video of Snazzy Labs and some posts in this and other forums.
Unfortunately my iMac does have the 128 GB PCI-SSD and a 2 TB HDD (Fusion Drive).
Is there a possibility to replace only the HDD with a 1 TB SATA SSD and reconfigure it as a Fusion Drive with the PCI-SSD?
Or, is it even possible to put in 2 SATA SSDs in there and setting up as RAID and then using as a part of the Fusion Drive?
Thanks for your help people!
Score 2
Add a comment
Most Helpful Answer
Lets first review what it is: Fusion Drive, simply put the SSD is a read/write buffer for the HDD.
So there is a limit of benefit with the size of the SSD and the cost of the SSD. Unlike HDD's SSD are still quite expensive! 4 to 5 cents per gigabyte for the hard drive and 25 cents per gigabyte for the SSD SSD vs. HDD: What's the Difference? So Apple tried to find the best SSD size for the given HDD they put in. I do think they should have continued using the larger SSD! But, they down sized! Apple slims 1 TB Fusion Drive down to a measly 24 GB of flash storage
So... Getting back to your Q's
If you need deeper storage then upgrading the HHD with a still larger HDD is possible. If you are looking for speed then swapping out the HDD with a SSD won't get you that much as the limit of the SATA III (6.0 Gb/s) interface is the limit here. As you have the older Fusion Drive model with the custom blade 128 GB SSD you're already hitting the max of the combined I/O channel as the SSD is doing its job of caching the reads & writes.
If we look at your systems SSD's PCIe slot 8.0 GT/s PCIe x4 its dam fast! So upgrading the blade SSD would be the best investment. And instead of configuring the system in a Fusion Drive config set it up as a dual discreet drive config so you are using each drive to the max for what they are best at.
Sorry to say you can't really RAID the drives in your system as the I/O speed difference will hold you back as the fastest you can go would be the slower of the two I/O's in this case the SATA 6 Gb/s Vs the PCI'e I/O 9 Gb/s.
Remember! Fusion Drives are only intended to be used across a HDD and SSD drive pair to improve the HDD's speed at a lower cost. Just like a SSHD is able to do the same thing within one drive.
The alternate option here is to just get an external Thunderbolt2 RAID drive (SSD) here we can push the I/O higher than the internal SATA ports limit as we can setup a RAID 0 config getting about 1 1/2 times (9 Gb/s) the throughput with 2 drives and 1 2/3rds with four drives (10 Gb/s) which is the limit of the Thunderbolt I/O within the system (directionally).
To put this into perspective: I have an older iMac I have a dual drive config 512 GB SSD and a 1 TB HDD which in my system is bottlenecked at SATA III (6.0 Gb/s). I also have a souped up MacPro (trashcan) with an external RAID'ed SSD which is connected with Thunderbolt2 RAID with 4 SSD drives. And I can tell you it screams!
So the bottomline here is break the Fusion Drive set and find the largest Apple blade SSD you can afford and put that in. Then migrate your OS and users accounts over to it and use your HDD for the deep storage. Or, get an external RAID'ed TB2 SSD drive migrating to it instead.
Score 3
3 Comments:
Hi, you say:
then migrate your OS and users accounts over to it and use your HDD...
Why do it with the user accounts? I have an old iMac (late 2009) with SSD + HDD which I updated following the guide here in ifixit but I have my user accounts in the HDD for capacity reasons ( 256 GB vs 2 TB)
Will I get better performance if I have the user accounts in the SSD?
Thanks, you guys rock!
by
This gets a bit tricky here ;-}
You do want the user accounts on the SSD, But! You want to use the HDD for the storage of your work.
The issue is how apps run they need scratch space and often leverage drive storage to hold temp files. So ideally you want these to be on the SSD which is why you need the user accounts on the SSD so it will be used (speeding it up). Then create a second folder on your HDD and place your files there.
Some apps allow you to alter the cache and temp spaces but you often need to get into setup file to make these alterations so just placing the user account on the SSD is easier.
by
Thank you Dan ;-)
by
Add a comment
Hi, I believe my HDD has some fault as sometimes my iMac (5k late 2014) get’s really slow.
So I would have basically 2 options:
  • install an SSD instead of a HDD and not use the fusion drive, but the blade SSD as a separate volume
  • replace the 3TB HDD like for like
The first solution doesn’t give much benefit, as the fusion drive is quite fast already, but it is quite expensive with a 4 TB SDD (I use 2,5 TB now so 4GB the size to go for)
The second solution (replacing the HDD) costs 80 Eur for the disk and something for the adhesives and that’s it. I also believe that economically that makes more sense as the machine is quite old already
Add a comment
Add your answer
Tobias Pörtner will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 11
All Time: 7,290
