The Kenmore 110 Series is an easy to use home Washing machine created by Kenmore.
500 Questions View all
Loud chunk-a chunk-a sound during agitate cycle
Hi there. It's a Kenmore 110.24732300 washer. It seems to work fine, just loud. Like in the laundry room shut the door still crank up the TV to drown it out loud. Only during agitate cycle. Chunk-a chunk-a chunk-a in perfect rhythm with the agitator. Hard to spot source but seems to be from agitator arm? The arm is kind of loose. If you lift straight up it will raise a half inch or so.
Add a comment
1 Answer
Chosen Solution
If your Kenmore 110 Series Washing Machine is making strange noises, see the Kenmore 110 Series Washing Machine Makes Unusual Noises problem page for possible causes and solutions.
Cause 1
Tub Bearing
The tub bearing is mounted in the middle of the outer tub. The tub bearing helps to keep the inner tub spinning smoothly. Replacing the tub bearing is a very involved repair and will require disassembling most of the washer. If the tub bearing is defective, we recommend replacing both the outer tub and bearing as an assembly if the manufacturer offers the components together.
Cause 2
Tub Seal and Bearing Kit
The tub bearing is mounted in the middle of the outer tub. The tub bearing helps to keep the inner tub spinning smoothly. If the washer is noisy during the spin cycle or is leaking from the bottom of the tub near the transmission, the tub seal and bearing are likely defective. Replacing the tub bearing is a very involved repair and will require disassembling most of the washer. If the tub bearing is defective, we recommend replacing the outer tub and bearing at the same time.
Cause 3
Rear Drum with Bearing
The rear drum has a bearing or bearings in it to keep the inner tub spinning smoothly. If the tub bearing system is defective the washer can become very noisy. On some machines bearings are sold separately from the rear drum, however, we recommend replacing both the outer drum and bearing as an assembly if the manufacturer offers the components together because removing and pressing in the new bearing can be exceptionally difficult. Be aware that replacing the outer tub and bearing is also not easy and can be very costly.
Score 2
Add a comment
Add your answer
Bill N will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 9
All Time: 526
