Repair guides and support for full size headphones that encompass the entire ear, also known as circumaural headphones.
108 Questions View all
How do I disassamble JBL S400 BT headphones
I have a pair of JBL S400 BT headphones, where sound is not working in right side. I suspect it is just a loose connection. I have fixed JBL headphones before by just soldering a loose wire.
But I'm not able to see how I can disassamble these headphones. There are no visible screws. So I guess that they are some how clicked or glued together.
I have tried to twist the parts and also used a flat screw driver to force it apart. But it didn't work and I'm worried that I'll break something.
I have search for videos and images but have found nothing so far on this model.
Any ideas?
Score 1
Add a comment
Chosen Solution
I found this video: https://www.youtube.com/watch?v=nkxpm-_F...
And I was able to lift of the JBL lid by using a small flat screwdriver. The lid is glued, so it is not easy to remove and the screwdriver left marks on the plastic. Maybe some plastic tools would have done a better job.
Add a comment
Have you taken off the earmuff things? in a different model they are under the earmuff things.
1 Comment:
Thanks. I have tried to remove earmuffs. But no screws on that side
by
Add a comment
Add your answer
Casper Skovgaard will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 20
All Time: 2,979
