The sixth-generation Volkswagen Jetta, known as the NCS (New Compact Sedan) during its development, was announced in the North American market in June 16, 2010.
20 Questions View all
Inspection light on after oil change
I have checked all the fluids and replaced the oil and oil filter. Now I have an inspect (Inspection light on) in dash. I tried to reset and it remains on during starting only. Can someone tell me what I should do next?
Score 2
1 Comment
The rest process did not work for me(wrench).
by
Add a comment
Chosen Solution
For Keyless Start:
Start with car turned off:
1. For Inspection Reminder Reset: Turn on Emergency Flashers. Then press and hold Reset/0.0 Button on instrument cluster and push the Engine Start button (without starting engine - foot off brake).
2. For Oil Change Reminder Reset: Don't turn on Emergency Flashers. Then press and hold Reset/0.0 Button on instrument cluster and push the Engine Start button (without starting engine - foot off brake).
For Key Start:
1. For Inspection Reminder Reset: Turn on Emergency Flashers. Then press and hold Reset/0.0 Button on instrument cluster and Turn key to "ON" without starting the car. Look at dash for further instructions.
2. For Oil Change Reminder Reset: Don't turn on Emergency Flashers. Then press and hold Reset/0.0 Button on instrument cluster and Turn key to "ON" without starting the car. Look at dash for further instructions.
Score 4
3 Comments:
I did this and acts like it reset then the warning comes back on seconds after resetting.
by
Same. It just removed some of the letters in the warning.
by
Thanks heaps. My oil warning light appeared after using jumper leafs on to my sons car. Using the reset emergency flashers/ 0.0 set on dash and putting key into start mode without starting did the trick!
by
Add a comment
For vehicles with ‘Basic Display' (wrench icon and INSPEC_ message)
Reset the Inspection reminder:
1.Switch off the ignition.
2.Switch on the emergency flashers
.3.Push the . button in the instrument cluster and hold down.
4.Switch on the ignition.
5.Release the . button and push the  button in the instrument cluster within about 20 seconds.
6.Switch off the emergency flashers.
To reset Service reminder:
Same process except don't activate hazard lights.
P.S. don't reset Service indicator unless the vehicle has been serviced or incorrect data will be displayed.
Score 1
1 Comment:
the magic word is 20 sec after the wrench Inspection appears
by
Add a comment
I reset mine and all is fine for approx two weeks then it tells me I need an oil change again! Any Clues?
1 Comment:
You may in fact have too much oil. Apparently their are minor diesel leakage from the injectors into the oil in Amroks. Oil builds up and triggers the warning light. The sensors are really sensitive to excess oil levels.
by
Add a comment
Add your answer
g3houdini will be eternally grateful.
Past 24 Hours: 11
Past 7 Days: 59
Past 30 Days: 238
All Time: 85,795
