The Nokia N9 is a smartphone made by Nokia running on the Linux-based MeeGo "Harmattan" mobile operating system.
12 Questions View all
Why is my phone not switching on?
I don't know what happened to the phone all of a sudden it went off. When trying to charge, the down light will be on just about 1 second and off. Please help
My phone's model is Nokia N9, 36792304 1041650.
1 Comment
have a look in the charge port for any lint or damage
by
Add a comment
1 Answer
Most Helpful Answer
Abigail,
If your led indicator comes on when the charger is attached, it is unlikely the charger port on the phone or the wall power supply are non-functional. However, it would be worth testing a new charger, one that is at least the 1.3Amperes your OEM Nokia charger is rated.
The next step in the diagnosis would be to open the phone. It has been several years since I have opened a Nokia N9. If I remember correctly though, you can remove one screw from inside the SIM tray area, then the screen will be free to unclip from the plastic outer frame and interior metal body of the phone. This generation of Nokia uses torx screws - t4, t4, t6, etc. A 0.5mm or 0.6mm guitar pick is excellent at unclipping the screens from these unibody Nokia's.
The first thing to test would be the phone's battery. If your battery is below 3.7Volts, than you cannot expect the phone to start. Above 3.7V, with good hardware and no software issues, the phone will start. If you are able to read the battery voltage, try plugging in the charger for at least ten minutes before reading the battery voltage again. If you start at one voltage, say 3.5V and the battery charges up to 3.8V, than the battery does charge. Investigate the possibilities of a software problem or faulty display hardware. An installed screen is not required to charge your battery. Make sure the battery is not plugged in before reinstalling other parts such as the screen. Your battery should be the last thing plugged into any system.
If you read 0V the first time you test the battery, you should still try plugging the phone into a charger for awhile and then checking the voltage a second time. If the voltage is still 0, your system is not charging. If you have access to a new battery, plug it in and repair the above steps. If the new battery still does not charge, your next step would be to replace the charger port and repeat your tests.
Score 1
Add a comment
Add your answer
abigail essah will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 17
All Time: 997
