2.2 GHz (Turbo Boost up to 3.4 GHz), 2.5 GHz (Turbo Boost up to 3.7 GHz), or 2.8 GHz (Turbo Boost up to 4.0 GHz) quad-core Intel Core i7 processor with 6 MB shared L3 cache.
786 Questions View all
Is the iFixit adhesive remover just isopropyl alcohol?
I am thinking about doing a keyboard replacement for my MacBook Pro but the battery must be pried off first. Instead of forcing it off, I found the adhesive remover in the store, but I’m hesitant to spend $33 for a solution that is similar to alcohol.
Has anything else worked for anyone?
Add a comment
Chosen Solution
Hi @davchun
Watch the provided link and at 8 Second, pause,
https://www.youtube.com/watch?v=8krNjKEs...
It mentions contain Acetone
, etc almond fragrance....
Score 8
2 Comments:
Check out aldon-chem website and search for sds, or google “aldon chem sds”. Chemical name “AA-0051”. The sds says it’s 99.8% acetone, 0.1% Cherry Almond Fragrance and 0.1% FD&C Blue #1 (C.I. No. 42090). It’s all public information.
by
Add a comment
Score 6
Add a comment
I went to Walgreens and get 100% acetone nail polish remover. It works
Score 3
Add a comment
I started using pure methanol a couple of years before iFixit found a solution.
Score 2
Add a comment
I am thinking of replacing my macbook pro battery. Hesitant to buy an adhesive remover. But wouldn’t the acetone/nail polish remover damage or erode the old battery and causing problems?? I mean the old battery should be pretty fragile, I suppose..
2 Comments:
[image|1948870]
yeah just go buy acetone lol
by
Acetone might affect the plastic covering but the actual battery cells are encased in metal. Acetone should be ok but I'd avoid nitric acid.
I replaced a battery just now and tried isopropyl alcohol (100%) on one side and acetone on the other side. I didn't find a lot of difference in how they removed the glue and I can say that both solvents struggled to dissolve it.
by
Add a comment
Is it just Concentrated Windshield Washer Solvent with Ammonia?
Score -1
1 Comment:
google aldon chem sds and search for AA0051. it's a mix of acetone, fragrance and blue dye.
by
Add a comment
Add your answer
David Chun will be eternally grateful.
Past 24 Hours: 9
Past 7 Days: 39
Past 30 Days: 142
All Time: 16,025
