Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
5s Blue Screen of Death Bootloop
Problem description:
The phone is stuck in an apple logo boot loop with Blue screen of death cutting it off.
I can break the boot loop if I leave the battery disconnected for some time, once I plug the battery back in and let it boot up it boots up fine.
Then if I switch off the phone and try to turn it on again it's stuck in the BSOD boot loop.
Then again to get it working I have to disconnect the battery again and do the above.
What I've checked:
- Checked screw holes for long screw damage, no damage visible there
- Tried booting with front camera, rear camera, charging port, antennas unplugged
- Tried booting via DC Bench power supply adapter
What I am going to do:
- Replace tristar charging chip (U2)
Should I try anything else first before doing so?
2 Comments
what about a nand reflow
by
I don't like reflows, I'll do tristar first.
by
Add a comment
1 Answer
Chosen Solution
Okay, problem solved, U2 Tristar replacement did the trick!
So for anyone with exact same symptoms on 5s, get tristar replaced to see if that helps.
Score 2
1 Comment:
Hi @benjamen50 ,
Seems like 'going with your gut feeling' is the way to go.
Cheers.
by
Add a comment
Add your answer
Ben will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 7
All Time: 523
