The Samsung Galaxy Light is an Android device released in October 2013 for T-Mobile with GPS, microSD card slot, and 8 GB memory.
12 Questions View all
Why is my phone restarting only to opening title screen, then freezes
When restarted the phone will only open up to the carrier id screed past the Samsung opening bell sounds. Unresponsive. Apps began to shut down after I did updates of apps I've been using. How can I save my photos & music?
Add a comment
1 Answer
Turn on and use safe mode
Safe mode allows you to turn on the device with third-party apps disabled. Then you can easily uninstall apps that may be causing a conflict or software problem.
Turn off the device.
Press and hold the Power key for one or two seconds to turn on the device.
When the Samsung logo displays, press and hold the Volume down key until the lock screen displays.
Uninstall apps that are causing a problem.
From any Home screen, tap the Menu key.
Tap Settings.
Tap the More tab.
Tap Application manager.
If necessary, swipe right to the Downloaded screen.
Tap the desired application.
Tap Uninstall and then tap OK.
Turn off safe mode
Press and hold the Power key.
Tap Restart. Tap OK.
Add a comment
Add your answer
Ruth Goddard will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 104
