Released in 2010, the Logitech G27 is an electronic steering wheel designed for Sim racing video games on the PC, PS2 and PS3.
44 Questions View all
Buttons on steering wheel not working, do you sell replacement wires?
I have a Logitech G27 racing wheel, the buttons and the shifters on the wheel it’s self have stopped working, I have pin pointed the problem being the wire that goes from the wheel to the base of the wheel, do you sell these wires or components?
Add a comment
Maybe a bit late, but this might help someone else coming across this question. You probably won’t be able to buy a assembled wire, however if you can find someone or learn the skills required to assemble it it should be easily replaceable. Most individual wires you can either get from a electronics/hardware shop, probably AWG 18 or 20 though I’m not entirely sure what size they are. Its more important that they fit in the crimp housing/socket, rather then a specific size otherwise.
You’ll also need to find some crimp wire housings/sockets to crimp on the wires (after stripping), you can find some on Farnell, Mouser or other similar component suppliers. The most tricky part will be finding one that will fit and stay in the housing, here’s a example one for reference (though I haven’t checked it’ll fit). See here for wire stripping and crimping: https://learn.sparkfun.com/tutorials/wor....
Depending on whats broken you might also need some heatshrink to cover the wires and keep them together. If your not comfortable with all of this I’d suggest seeking out someone more familiar with electronics/wiring.
1 Comment:
Couldn't you just buy a broken g27 thats for parts and use the connector from that?
by
Add a comment
You can get supplies like this from Mouser Electronics
https://www.mouser.com
Add a comment
Add your answer
Daniel williams will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 14
All Time: 1,364
