Released June 2016, identified by model number A3003 in Europe, A3000 in China and North America (according to https://forums.oneplus.net/threads/oneplus-3-regions-model-numbers.452381/)
67 Questions View all
phone dead, no led no hard reset reboot or charging.
few days ago i was charging my phone it was at 40% and the screen went blank, it wasn't the normal way when the screen goes off i knew something was wrong, first i try to switch on the phone it didn't work, next i tried to hard reboot the phone it still didn't work, i connected the charger the led wont light like normally even if the screen went blank or battery run low the notification led will glow still it didn't the phone is totally dead please help me out. should i replace the battery or should i try something else?
Score 3
3 Comments:
Have you made any progress? I'm in the same situation with a OnePlus 5.
by
My op1 did this. It's basically parts at that point. I tried replacing the battery but that didn't work.
by
what kinds of the hardware issues related to this problem? cause i have facing same problem here????
by
Add a comment
Have you tried the unbrick tool from the following link?
https://forums.oneplus.com/threads/guide...
If method 1 or 2 fail to resolve your problem then it's likely a hardware issue.
From your description, your phone might be in a very similar situation to mine, so if you resolve it, please let me know. :)
1 Comment:
I had the same issue, i tapped the whole phone face down on to my left palm then tried switching on. It just came to life. Try it, it might work on every phone. And also a day before it just fell out of my pocket, that made me think that a similar shock might rescue it. And it came to life with 8% charge. If im right, it was about 80% then it became dead , and it was just 5 hours ago. Try this trick.. nothing is beyond death, if it breaks into two it doesn't matter.
by
Add a comment
One plus 3 charging ic no
Add a comment
Add your answer
yogesh gokhale will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 3,004
