Repair guides for the HP LaserJet 1160/1320, a laser printer made by HP. The LaserJet 1320 has a duplexer and networking options, but the LaserJet 1160 does not.
11 Questions View all
Why does the printer drag other white sheets and then lock them?
The HP 1320 printer is connected to the PC via USB. Windows 10 as an oparative system. When I print the printer, drag other sheets and lock. Other times it prints other white sheets. Manual two-sided printing from the front drawer, however, works correctly. I have updated the drivers, changed the PC, changed the operating system: the result does not change. What can it be? Thank you.
3 Comments:
Are you saying when, that sometimes when you print it drags other sheets of paper through with it. This then locks up your printer?
by
Yes. When I print:
1 - a white sheet or, sometimes, correctly printed, comes out
2 - a second white sheet gets stuck in the upper part
3 - a third white sheet gets stuck in the lower part (just drawn from the tray)
4 - the printer stops
5 - the central LED flashes
see the b&w photographs
by
[image|1378795][image|1378797]
by
Add a comment
1 Answer
How long have you had this printer? You may need to install a maintenance kit. Your pickup rollers are probably worn out.
2 Comments:
The printer is 10-15 years old. How to check the wear of the rollers?
Question: if the rollers are damaged, why are more sheets pulled?
by
Take the paper tray out and look inside of the printer at the top. Youll see a gray roller. Visually and physically inspect it to see, if it's smooth. It needs to be rough feeling all the way around in order to pickup paper properly.
by
Add a comment
Add your answer
Lore will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 107
