Model A1311 / Late 2009 / 3.06 or 3.33 GHz Core 2 Duo processor
Pixilated screen :Video controller error 4V DC 1140000003
My Imac boots up intermittently to a pixilated screen, or a white screen with vertical bars, sometimes goes as far a desktop, but that is pixilated as well and freezes. The AHT shows this code: Video controller error 4V DC 1140000003. External monitor shows the same pixilation as main monitor. My Question is where the video controller is located, and if I can fix this by simply replacing the logic board. Thanks for any tips.
1 Comment
Thank you Dan. I have the MXM daughter board , and I just send it of to California to get repaired. We will see how that pans out. Cheers, J
by
Add a comment
1 Answer
Chosen Solution
Depending you your model it either uses an onboard GPU so you'll need to replace the complete logic board or you have the higher end model which uses a MXM daughter board which might be all you need.
Here's the IFIXIT guide you'll need to follow: iMac Intel 21.5" EMC 2308 Logic Board Replacement and you'll need one of these:
Intergraded Graphics:
  • 3.06 GHz - 661-5305
  • 3.33 GHZ - 661-5306
MXM Graphics board:
  • 3.06 GHz - 661-5307
  • 3.33 GHZ - 661-5420
Score 1
Add a comment
Add your answer
Jurgen will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 105
