Released in 2015, intended as a workstation for CAD CG professionals, or as small-scale business servers.
2 Questions View all
Battery good but not cahrgin anymore
My M3800 suddenly stopped working with an AC adaptor, won't charge the battery, won't operate without the battery. I have several AC adaptors and none of them work now (the power adapter are good as they work for other laptops).. Any ideas??
What is the IC mofset component on those that handle the charginf of battery?
thanks
w
Score 1
2 Comments
I have a similar issue; My Dell Precision M3800 reports during boot that my charger is insufficient, and that performance will be adjusted accordingly. And it no longer charges the battery.
It says the I need a 130W adapter.
But I do have a 130W adapter, and this adapter works without any issues on other M3800 Dell machines.
What can be the reason for this issue, and what should I do?
by
@Oyvind Overby Sense IC is bad. Dell had some issues with the early 130W units, which were prone to that issue. I went through quite a few when I had my E6540 as well. They fixed it in the later revisions, and new design.
If it's got a Dell logo molded into the plastic, be glad it's worked this long.
by
Add a comment
1 Answer
Chosen Solution
Hi,
Just verifying that the laptop will not work with the AC adapter connected and the battery removed, is this correct?
It may be that the DC-In jack is faulty and not that you have a problem further into the motherboard.
Here is a link to the owner manual for your laptop.
Scroll to p.21 to view the necessary pre-requisite steps and then the procedure to remove/replace the power connector, (DC-In jack).
You are fortunate that this is a plug in module so if it is faulty it is easy to replace, no soldering required. (use an Ohmmeter to test if it is OK out of circuit)
Here is a link to just one supplier of the part. It is not a recommendation to use them. It is shown to give an idea of the cost of the part. There are other suppliers online that may suit you better. Just search for Dell Precision M3800 Dc-In jack part for results
Score 2
Add a comment
Add your answer
Wilhelm THOMAS will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 19
All Time: 820
