Model A1237 or A1304 / 1.6, 1.8, 1.86, or 2.13 GHz Core 2 Duo processor
No video at all
Hi everyone, I hope someone could assist me to repair my MBA first gen, so the problem is , after I press on/off button, it looks or seems to be starting, chime sound on, the fan is turning, caps-lock key turn on when I pressed, but still not showing any video or displaying something just got blackscreen, and I try to add some baclklight effect from other small torch, it shown nothing either....
what should I do....kindly need your hellp or assist to solve my problem,
thank you
Add a comment
1 Answer
Most Helpful Answer
To isolate the problem hook it up to an external monitor and let us know the results. Have you had any problems with your hinges or spilled anything on it. You can try to access the hard drive by using Target Mode and hooking it up to another Mac via a Firewire cable and booting holding down the "T" key.
Score 1
4 Comments:
I havent try to connect it to external monitor yet, I'll try it later at home, but I'm sure nothing spilled into or on it, I did try removing the hard drive and start it, but once again it just the same, no white screen, no circle turning, no apple logo, no light, nothing, just chime without change or error message that I can see... is there any other step wich I can try, please your assist....
by
I did try to connect to an external display, but still not showing anythings, and I also try a SMC reset from your refer page, done that but still no magic, this very frustating, and now even worst, after several try of restarting, open/close lid now it just get sudden turn off 3 second after I press on/off button, no chime....
please help me....
by
I have the same problem. Black screen, no sound, no keyboard light, Fan is working and the from white light is working almost off.
by
Add a comment
Add your answer
Daniel Fajarsyach will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 3,514
