The second generation (chassis model L30) was an American market-only version, again styled by Nissan's California design center under Doug Wilson through 1994 (design freeze in 1995).
8 Questions View all
P1105 code is not going away
I've replaced map sensor, code still shows. What's the issue?
Add a comment
1 Answer
Chosen Solution
@smooch a failed MAP/Baro Switch solenoid can give you the same code. Check for more reasons for code P1105 on here If that solenoid does not open then your sensor does not get a vacuum and will read barometric pressure which will trigger this code. Check the solenoid by unplugging the vacuum hose on the sensor and attach a vacuum gauge to that. Start your car and within seconds your gauge should read a vacuum. If there is no vacuum then it is most likely that your solenoid has failed. Of course this will only work if your vacuum hoses are not cracked etc.
Score 2
Add a comment
Add your answer
Quinton Higgins will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 28
All Time: 4,299
