Electrolux PLD2850RDC2 or Frigidaire PLD2850RDC2 dishwasher. Stainless steel door with plastic tub.
dishwasher does not heat
replaced the heating element and it still does not heat
Score 1
Add a comment
1 Answer
Most Helpful Answer
Cause 1
Heating Element
Some dishwashers use a heating element to heat the dishwasher during the drying cycle. If the heating element has failed, the dishwasher won’t dry dishes properly. To determine if the heating element has burned out, use a multimeter to test it for continuity. If the heating element does not have continuity, replace it.
Here's the part for your machine, thanks for providing the model number ;-)
https://www.repairclinic.com/PartDetail/...
Score 1
2 Comments:
I have replaced the heating element and it still dos'nt heat
by
Hi @Fritz Mehrer,
Just wondering if the Hi Limit Thermostat may be faulty preventing the heater element from being turned on.
The page tells you how to test it.
Located as part #F29 from this page
by
Add a comment
Add your answer
Fritz Mehrer will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 18
All Time: 1,670
