Repair manuals and information for the Microsoft Surface line of tablets.
My charger doesn't charge.
After going down from lack of battery, my tablet won't charge. The charger Light doesn't turn on, and I need some solution that doesn't involve buying a new one or throwing everything against the wall...
Score 2
1 Comment
Just tested with a multimeter, and apparently the charger is working...
The problem must be in the battery.
by
Add a comment
1 Answer
Chosen Solution
@gc05 you could check your charger with a multimeter first to make sure that it is working. If it is then you are possibly having issues with either the charging port Microsoft Surface Charging Port Replacement or the battery. If your battery is depleted or discharged below the charging threshold it will no longer accept a charge. Replace the battery and see if that works. Microsoft Surface Battery Pack Replacement
Microsoft Surface RT Battery Pack Image
Guide
Difficulty:
Moderate
5 - 10 minutes
Microsoft Surface RT Charging Port Image
Guide
Difficulty:
Moderate
15 - 30 minutes
Score 2
Add a comment
Add your answer
Gil Cancela will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 10
All Time: 25,352
