Released in June 2017 as a successor to the Surface Pro 4. Also known as Microsoft Surface Pro 12.3". Model number: FJT-00001.
52 Questions View all
Heat Gun/Blower for Screen Replacement
I am looking at purchasing a heat/gun blower to replace my Surface pro 5 screen (warm the adhesive to weaken it)....as well as for other electronics.
I have come across 3-in-1 Function Heat Blower and Soldering Iron (see link below), which I thought could be helpful with other projects also.
https://www.jaycar.co.nz/3-in-1-function...
Has anyone had any experience using this type of "heat blower"? First thought is it may be difficult to control the temperature...although it does have a flame adjustment setting.
Thanks in advance for your help.
Score 1
2 Comments
Hi @dgmossman ,
You may wish to take note of the warning at Step.1 in the ifixit Microsoft Surface Pro 5 Screen Replacement guide.
Just a thought.
by
Go for an iopener, otherwise it's too easy to damage the surface.
by
Add a comment
Chosen Solution
I think the soldering gun you picked will be to narrow an area and far to hot to do the job well. I believe you chances or success on this repair would be much greater with a standard heat gun:
Heat Gun
Heat Gun Image
Product
Heat Gun
$24.99
Score 2
Add a comment
Most Helpful Answer
I would use the iOpener or a heatmat.
Score 2
Add a comment
Add your answer
Daniel Mossman will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 11
All Time: 1,263
